I want to measure the torque constant of a stepper motor but seems I am doing it wrong. I have an MST342C02 stepper motor (200 step/rev and 4 phases) with SMD42C2 Driver. I have a converter that gives 48VDC 12.5A from 110VAC. I have Teensy 4.1 as the microcontroller and use Accelstepper library. The motor is connected Bipolar Parallel. the motor has:
Holding Torque = 9 Nm
Phase Current (A) = 9.5 (parallel), 4.7 (series)
When the motor is stationary the current is 0.4 A. However, by looking at the driver manual, for a 4 phase motor in parallel, the max current is 1.41*(Nominal current per phase). So for my configuration, we would have 1.41 * 9.5 = 13.4 A. I searched the net for the torque constant and some said it's (Holding Torque)/current = 9/13.4 = 0.67.
The motor datasheet graph has 7 Nm for 300 RPM. I run the motor at this speed with PWM 255 which gives the max torque. The Measured current at such speed is 1.48 A. Also, the motor datasheet for 600 RPM has 6.2 Nm. Now I set the motor to this speed with PWM 128 for half torque (motor jams at max torque, but I don't know why) then the measured current is 0.83 A. Using the graph this should be 3.1 Nm. Now the torque constant is 7/1.48 = 4.73 or 3.1/0.83 = 3.73 which does not comply with the 0.67.
  • \$\begingroup\$ The comments were largely a useful ongoing technical discussion. I have moved this conversation to chat. Please conduct technical conversations in chat so any new points raised by others can be seen in comments. Prior comments in chat here. \$\endgroup\$
    – Russell McMahon
    Apr 11, 2022 at 11:59
