to start off, i dont really understand about electrical engineering. im a mechanical engineering student tasked to continue the project. i dont really understand electrical stuff beside the very basic stuff.
the data we have:
- wire resistance (Rn): 0.85 ohm/m
- voltage: 220 volt (actually 3 phase but i've been told that we'd use each phase separately, so i think its 220 v, but still not too sure about it)
- specified power output: 7000 watt
these are what i've calculated, but still not sure if there's anything wrong in it:
- Current = P/V = 7000/220 = 31.8 ampere
- Resistance required = P/I^2 = 7000/31.8^2 = 6.91 ohm
- Required length = R/Rn = 6.91/0.85 = 8.13 meter
the thing is, previous project uses up to 75 meters. a lot more that what my calculation shows, which is 8.13 meters.
so, did i calculate it wrong? if so, how do i properly calculate this?
did i calculate it wrong by calculating current based on required power output? shouldnt it be power input from power line which i still have no data yet, beside voltage and it being 3 phase?
another data i forgot to add:
- the target temperature is around 1000°C
- power input: 3 phase, 10 A, 220 V, 6600VA
thanks in advance
