I'm looking to power 3 servos and control them with an Arduino Uno.
Could someone please explain to me, not just specifically for this, how I can work out how much voltage and current I need to power several motors at maximum power? I've heard that it doesn't matter how high of a current I supply as the motors will only draw what it needs from the battery. Is this true? If so how do I know the minimum current I must supply? As for the voltage, I've heard things like for a 6V motor you can use 6V to power up to 4 motors. If this is true, why is 4 the cutoff? And does that mean I need 6.8V for these?
Also how do I choose which type of battery to go for? This needs to be portable so I can't have mains connections, so how do I choose between the AA type of batteries, LiPo or Nickel, etc..?
Sorry for the basic questions, just trying to build up from the foundations.
The specs for the servo indicate about 2A at stall, with a supply voltage of 5 to 6.8V. You can use any voltage in that range regardless of the number of servos you’re using. If all of the servos could operate at the same time then you’ll need a current capability of 2A per servo, so 8A for 4 servos (plus a little bit for the Arduino). You could use 5 NiMH cells giving about 6V, but 8A is quite a bit for AA cells. 18650 lithium cells have a much higher current capability (some up to 40A) but the voltage isn’t ideal to use directly so you’d need a DC-DC converter. Unless you need maximum servo torque you might stick to 5V which can power the Arduino directly.
  • \$\begingroup\$ Ah, thank you very much. So since I need 3 of these servos, 4x AA (Ni/MH) batteries wont suffice as they can't output 6 Amperes at once? \$\endgroup\$
    – user270727
    Commented Apr 12, 2022 at 23:48
  • \$\begingroup\$ 4 AA cells will give you 4.8V which may be ok. 6A is a tall order from AAs, but if the servos won’t be loaded to stall you might be ok. If necessary you could parallel another 4 cells. \$\endgroup\$
    – Frog
    Commented Apr 13, 2022 at 19:45
