I am doing a project on proteus,I cannot find the ground terminal, where can I find AGND(Analog ground) and PGND in proteus?
1 Answer
In the left hand menu of Proteus, go to the "Terminals" tab and you'll find the symbols for power, ground, input, output and others. connect this to your circuit and simply re-name the net to PGND or AGND
\$\begingroup\$ oh, I thought because have different functions so cannot use that ground. so is it possible to use just rename only? \$\endgroup\$ Apr 13, 2022 at 17:08
\$\begingroup\$ You need a GND reference pint for the circuit to simulate correctly, so you'll need these. You can then just rename the nets \$\endgroup\$– MCGApr 14, 2022 at 7:22
