For the following circuit, I need to find the small-signal impedance looking into the collector of the transistor at terminal X, not taking the load resistance Z into account:
My attempt at a SSM is: enter image description here
Now, as I understand it, the small signal impedance looking into the collector is just another way of saying output impedance (please do correct me if I am wrong). So we essentially need to find the small signal output impedance from the SSM.
To do so, we need to short the input, and apply a test voltage at the output. However, I can't see just by inspection what the input and the output even are on this SSM. Is \$v_{be}\$ or \$v_b\$ the input? Is \$v_{ce}\$ or \$v_c\$ the output?
My intuitive guess would be the input is between the base and small signal ground, \$v_b\$, and the output is between the collector and small signal ground \$v_c\$. But I have no real logic to justify this.
And if that were the case, if we shorted the input, we would be connecting the base to ground. And hence, the parallel combination of R1 and R2 should disappear in the calculation of output impedance.
But, as it turns out, the expression for the small signal output impedance is: enter image description here
And it does include the parallel combination of R1 and R2 (denoted \$R_{12}\$ here).
So, I'm sort of at a loss here, and clarification on (1) firstly identifying the inputs and outputs of the circuit and (2) why \$R_{12}\$ appears in the expression for small signal output impedance, would be much appreciated.
  • \$\begingroup\$ If we want to find Rout we are looking from the load resistance perspective. In this case, we see two paths for the AC current to flow. The first path is through Z resistance and the And the second one through BJT's From colletor into BJT collector. So, to find resistance seen from the collector terminal into the BJT we need to use a small signal model. \$\endgroup\$
    – G36
    Apr 13, 2022 at 12:29
  • \$\begingroup\$ So in this case the input (for our test voltage ) is at the collector. Look here electronics.stackexchange.com/questions/613568/… \$\endgroup\$
    – G36
    Apr 13, 2022 at 12:34
  • \$\begingroup\$ @G36 Regarding your first comment, I have used a small signal model (or at least attempted to). \$\endgroup\$
    – VJ123
    Apr 13, 2022 at 13:09
  • \$\begingroup\$ As for the second question, it looks like Vin source is connected via R1. And this is why R1||R2 are included in SSM. electronics.stackexchange.com/questions/265046/… \$\endgroup\$
    – G36
    Apr 13, 2022 at 13:28
  • \$\begingroup\$ Today I found time to check your equation for Rout. It looks like a mess but despite this it is correct. Personally prefer this version $$ r_{out} = \frac{1}{h_{oe}} \left(1 + \frac{R_E}{R_E+(h_{ie} + R_{12})}\beta\right)+R_E||(h_{ie} + R_{12})$$ \$\endgroup\$
    – G36
    Apr 14, 2022 at 13:49
