I'm having an issue that I can't resolve on my own. I nested a 2-to-1 mux module inside of this 5-to-1, and no errors occur. Yet my output "m
" will only load in certain conditions and is x for most others. Can anyone point me in the right direction here or point out what I'm doing wrong?
I attached the code in Quartus along with an image of the output in ModelSim.
You'll see below commented out code for the testbench. I've just been testing different cases trying to get it to work.
// This module represents a five-bit mux that allows us to select one of five inputs
// NOTE: the way the circuit is depicted does not allow for a five vector mux, thus only the select bit is an array
module Mux_5_to_1 (u, v, w, x, y, s, m);
input u, v, w, x, y;
input [2:0] s;
output m;
wire a, b, c;
// Going to use 2 to 1 mux module that references the work for modelsim; no assignment necessary. inputs are specific
Mux_2_to_1 unit0 (u, v, s[0], a); // u and v
Mux_2_to_1 unit1 (w, x, s[0], b); // w and x
Mux_2_to_1 unit2 (a, b, s[1], c); // u & V and w& x
Mux_2_to_1 unit3 (c, y, s[2], m); // all with y for m
endmodule
module Mux_5_to_1_testbench();
reg u, v, w, x, y, s;
wire m;
// Instantiation
// Mux_5_to_1 DUT(u, v, w, x, y, s, m);
Mux_5_to_1 DUT(.u(u), .v(v), .w(w), .x(x), .y(y), .s(s), .m(m));
initial begin
// int k;
// int j;
s = 0;
for (int k=0; k<8; k++)
begin
{u,v,w,x,y} = $random; #80;
for (int j=0; j<9; j++)
begin
{s} = j; #10;
$monitor(u,v,w,x,y,s,m);
end
end
u = 0; v = 0; w = 0; x = 0; y = 0; s = 000; #50;
u = 0; v = 1; w = 0; x = 1; y = 0; s = 000; #50;
{s} = 001; #50;
{s} = 010; #50;
{s} = 011; #50;
{s} = 100; #50;
{s} = 101; #50;
{s} = 110; #50;
{s} = 111; #50;
end
endmodule
Below is the example of output "m
" having red lines (x cases)
The Mux_2_to_1 code is:
// This module represents a 2 to 1 Mux
module Mux_2_to_1 (x, y, s, m);
input x, y, s;
output m;
// wire
// x AND !s
assign M1 = (x & ~s);
// !s AND y
assign M2 = (s & y);
// both AND gates
assign m = (M1 | M2);
endmodule
module Mux_2_to_1_testbench();
reg x, y, s;
wire m; // functions with or without this line. Haven't figured out why it's necessary
// instantiation is necessary to actually load the module variables for testing. Won't through error without line but crucial.
Mux_2_to_1 DUT(.x(x), .y(y), .s(s), .m(m));
// Can also do "Mux_2_to_1 DUT(x, y, s, m);", We don't need to do the formatting to get the output.
initial begin
$monitor(x,y,s,m); // Has output and is formatted as such in C language. Will output when ran in Matlab. ex: "formatting", variables
x = 0; y = 0; s = 0; #50;
x = 0; y = 0; s = 1; #50;
x = 0; y = 1; s = 0; #50;
x = 0; y = 1; s = 1; #50;
x = 1; y = 0; s = 0; #50;
x = 1; y = 0; s = 1; #50;
for (int i=0; i<9; i++) // WARNING: putting brackets for "for loop" causes compile error
begin
{x,y,s} = i; // {MSB, ..., LSB} = i ; this is converting to binary output across vars when cycling through i
#10;
end
end
endmodule
