Consider an ideal LC tank oscillator offset by an ideal battery*:
The core question is this: is the energy balance here maintained by the charge-voltage relationship of the battery? Energy seems to be violated looking at just the cap and inductor:
- The inductor current and capacitor voltage oscillate sinusoidally.
- The capacitor energy is quadratic in
V_cap
relative to ground which is offset byV_rail
, while the inductor mean current is 0, so the capacitor's energy peaks are taller than the troughs while the inductor will have equal positive and negative energy peaks.
This is where the asterisk (*) comes in. I'm not sure what an "ideal battery" model actually entails. If it holds voltage constant, is it inherently non-physical? How do real-world batteries behave?
** This is motivated by an actual design decision I am making for a clamping diode (**) to know the expected power dissipation from clamping positive overshoots vs. negative ones near ground.
i_L(t)*V_rails
term! Thanks for the pointer. \$\endgroup\$
