I am working on a school project. I want to change tracks/signals but am struggling to find a solution for it.
What I want to do is have say 6 input signals/tracks which are then shifted between 12 outputs with a push button or a switch. I can then go between the breadboards without plugging and unplugging the wires
I made this diagram here:
I was doing some research and saw these multiplexers. You can control them with high/low and so on but with multiplexers it says it can only have 1 output so not sure if it will work. That is how far I have gotten. I am at a road block so came here for some help.
