I have the following RLC circuit. I am having trouble finding an expression for the natural response of this circuit. I found a similar question, but I was unable to simplify exactly like was done in the question: How to construct a differential equation from this RLC circuit?
Here is what I have done so far.
From KVL: $$V_l + V_c + V_{out} - V_{in} = 0$$
From KCL: $$I_1 + I_2 + I_3 - I_{in} = 0$$
Find currents: $$I_3 = \frac{V_{out}}{R_1} , I_2 = C_2\frac{dV_{out}}{dt} , I_1 = \frac{1}{L_2}\int{V_{out}dt}$$
$$I_{in} = C_1\frac{dV_c}{dt} = \frac{1}{L_1}\int{V_ldt}$$
Differential equation: $$\frac{1}{L_2}\int{V_{out}dt} + C_2\frac{dV_{out}}{dt} + \frac{V_{out}}{R_1} - C_1\frac{dV_c}{dt} = 0$$
The problem is I can't find a way to reduce the equation to one variable Vout. Vc cannot be simplified to only Vout. Vl needs to be known.
If Vc is found: $$V_l = L_1\frac{dI_{in}}{dt}$$ $$V_c = V_{in} - V_{out} - L_1\frac{dI_{in}}{dt}$$
Then Substituted: $$\frac{1}{L_2}\int{V_{out}dt} + C_2\frac{dV_{out}}{dt} + \frac{V_{out}}{R_1} - C_1\frac{d}{dt}(V_{in} - V_{out} - L_1\frac{dI_{in}}{dt}) = 0$$
But now Vin and Iin need to be known to simplify the equation. Their definition includes Vc, so it will just go round in circles. Does anyone know how to simplify to only Vout?
    \$\begingroup\$ I3=Vout / R1. This needs to be fixed as a start. \$\endgroup\$
    – user4574
    Apr 18, 2022 at 1:28
  • \$\begingroup\$ You cannot specify both the input voltage source and the input current for it. Doesn't work. But assuming \$V_x\$ is the node between \$L_1\$ and \$C_1\$ and that I didn't make a mistake, KCL has:$$\begin{align*} C_1\frac{\text{d}}{\text{d}t} V_x+\frac1{L_1}\int V_x\:\text{d}t&=C_1\frac{\text{d}}{\text{d}t} V_{_\text{OUT}}+\frac1{L_1}\int V_{_\text{IN}}\:\text{d}t \\\\ C_1\frac{\text{d}}{\text{d}t} V_{_\text{OUT}}+C_2\frac{\text{d}}{\text{d}t} V_{_\text{OUT}}+\frac1{R_1}V_{_\text{OUT}}+\frac1{L_1}\int V_{_\text{OUT}}\:\text{d}t&=C_1\frac{\text{d}}{\text{d}t} V_{x} \end{align*}$$ \$\endgroup\$
    – jonk
    Apr 18, 2022 at 3:29
    \$\begingroup\$ sparpo, I'm hoping you realize this will not be a trivial excercise, since it is a 4th order bandpass (4 states: 2xL+2xC). A quick solve with wxMaxima shows it can't apply the inverse Laplace, and Wolfram, well.... +1 for the effort, though. \$\endgroup\$ Apr 18, 2022 at 8:01
  • \$\begingroup\$ @jonk Iin was just meant to represent the current in C1 or L1, not a specified current. I can see this might be unclear. With that equation, you still have 2 variables to solve, it still can't be simplified to only in terms of Vout? \$\endgroup\$
    – sparpo
    Apr 18, 2022 at 10:13
  • \$\begingroup\$ @sparpo Does the work I show help, then? \$\endgroup\$
    – jonk
    Apr 18, 2022 at 10:14
As @jonk suggested, a shift in s-space give this ...
Ok, don't try to see the "result" function.
It is more easily as there are no "initial" conditions ...
Also, a plot with some values ... (did not verify against "simulation" ... to be done).
    \$\begingroup\$ I think OP wants it solved symbolically. That's why I said it's not trivial, because the roots of the denominator, only, take a fullscreen print with zoomed out text (and missing parts). :-) \$\endgroup\$ Apr 18, 2022 at 21:29
  • \$\begingroup\$ EET should be used? \$\endgroup\$
    – Antonio51
    Apr 19, 2022 at 5:01
