Problem:
I am trying to figure out how to interface an LCD via SPI.
What is known:
  • It is 80x32 dot matrix.
  • There are 23 pins on a flex cable.
  • The pinout. I'll put it below. The LCD is marked with red on image.
  • I've been told that the controller is sbn1661g.
LCD is from Motorola advisor pager, but I want to use it with esp8266. Any suggestions and critique counts since I am not a professional. Thanks a lot.
LCD pinout
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
SPEAKER ON DISP_A0 DISP_E1 DISP_E2 DB 0 DB 1 DB 2 DB 3 DB 4 DB 5 DB 6 DB 7 VDD V5 V3 V2 V4 V1 BACKPLANE
LCD pinout
The LCD has no SPI compatible interface to connect to. Consider a GPIO expander with SPI or I2C bus to interface it, or maybe something more basic like serial to parallel shift register.
