Can someone help me with the basic working of this capacitive touch switch? I know it isn't very complicated but I just can't get over my brain block of what actually triggers when the button is pressed. Transistors have always been a frustratingly confusing topic for me, and I'm having trouble figuring out how the NPN output wire works.
What I do get: Connecting the LEDs to ground allows current to flow across, those make sense to me. Pressing the button causes the control unit to change the voltage it is outputting to the transistor base. This either causes current to flow or not flow. Looks like I would add a load across the NPN and V+ wires. I'm guessing the purpose of this is to measure the current, which is what triggers from a button press, but about here is where I get shaky.
