These capacitors are located in power supply module DPS-279BPA
section where it is marked with high voltage area. It is a Phillips LCD televisionPhillips 37PFL5603D/10
with no picture and audio, Though it shows the power light in front panel. After I opened the back lid and noticed that these 3 capacitors turned black. Not sure if damaged or not. Other similar cap are still blue in original color. Not having multimeter and ESR I am not able to test these these out.
I guess replacement parts will cost less than the multimeter or other measuring devices so thing to just find the replacement part and replace and see if really needed go for other options.
I hope I am not in a wrong place, I am sorry that I could not be detailed than this!
I tried to search the actual part specifications as suggested but was unable to find appropriate no. I have uploaded the some more pictures hope helps. The Manual suggested looks similar.
