I'm trying to source some battery contact connectors for sliding straight metal strips into. They're the sort of thing that are used in power tool batteries, but I want to use them for a different project.
Example Photo 1
Example Photo 2
Can anyone tell me what these are called and any example part numbers / links? I've tried searching for things like "battery contact", "power tool battery contact" and a few similar terms, but have drawn a blank so far.
For reference, the ones in the photo came from a Makita Battery Case Kit that you can buy to make DIY power tool batteries.
  • \$\begingroup\$ "What are these connectors?" is allowed, but "Where can I get them?" isn't. \$\endgroup\$ Commented Apr 22, 2022 at 11:08
  • \$\begingroup\$ @user253751 - okay: I've edited the question accordingly \$\endgroup\$
    – DrAl
    Commented Apr 22, 2022 at 11:13
    \$\begingroup\$ Every OEM wants to protect it's proprietary charger interface with some custom parts and physical uniqueness. What makes you think otherwise? \$\endgroup\$ Commented Apr 22, 2022 at 12:56
  • \$\begingroup\$ You might find bus bar connectors or some kinds of fuse clips as substitutes. \$\endgroup\$
    – DKNguyen
    Commented Apr 22, 2022 at 15:09
    \$\begingroup\$ @TonyStewartEE75 The ones I photographed were off a copy of the Makita battery from a Chinese supplier. I've found several suppliers of these "Battery Kits", all of which include the same connector. Given they seem to have slightly different versions of the battery connector PCB, I assume they're from different manufacturers (and probably not Makita). Therefore I assume that the connectors can be bought. I don't know for certain though. \$\endgroup\$
    – DrAl
    Commented Apr 22, 2022 at 15:37
They are "spring leaf socket PCB terminals". The ones in your pictures are custom made. You can buy similar ones off-the-shelf:
https://www.aliexpress.com/item/1005003287167688.html?gatewayAdapt=glo2fra
enter image description here {AliExpress}
  • \$\begingroup\$ One , two or three pairs of contacts.... \$\endgroup\$ Commented Apr 22, 2022 at 18:02
    \$\begingroup\$ Brilliant, thank you! \$\endgroup\$
    – DrAl
    Commented Apr 23, 2022 at 10:40
