I am currently running into a problem in KiCad where the ground plane won't connect to some pads.
KiCad even tells me to connect them but doesn't seem to make the connection automatically.
  • \$\begingroup\$ What are the settings on the zone and the pads? \$\endgroup\$
    – Hearth
    Apr 23, 2022 at 16:09
  • \$\begingroup\$ they need the same signal definition just any other wire to pad. \$\endgroup\$
    – old_timer
    Apr 23, 2022 at 16:15
  • \$\begingroup\$ and/or when you run the rules check part of that is it computes the ground plane connections... \$\endgroup\$
    – old_timer
  • \$\begingroup\$ Things to check for: thermals (for the ground polygon, for the pads); any keepout zone in pcb or footprint? Overlapping pads in the footprint? \$\endgroup\$
    – DamienD
    Apr 23, 2022 at 16:16
I just checked the settings of the plane and realized that pad connections were turned off. I placed another pad and KiCad turned connections on automatically. It was just a dumb mistake on my part; I thought they were enabled by default.
Thanks for the comments as they made me double-check the settings.
  • \$\begingroup\$ what settings have you changed? where they are? \$\endgroup\$ Mar 4, 2023 at 15:23
  • \$\begingroup\$ If you look at the copper zone properties (click on the plane and press e) you will see a Pad Connections: drop down under Electrical Properties. You can pick Solid, Thermals, None, etc \$\endgroup\$
    – skot9000
    Jun 8, 2023 at 0:34
