I am looking to combine a cheap wifi baseband/mac chipset with a STM32 F1 or F2 MCU to run the IP stack.
I have to use the cheap USB wifi dongles or use SDIO/SPI interface and port the drivers.
I am facing a problem in finding the correct chipset which has datasheets / opensource drivers to continue with this work. The problem with Atheros / Broadcomm is they do not give datasheet unless an NDA is signed.
My only requirement is the chipset should be able to act as "Access point" for initial configuration.
  • \$\begingroup\$ If you want to use a USB dongle, you'll need a chip with a USB host interface, such as the F4. I don't believe that's available in the F2 series - generally the lower end parts have at most a USB device interface. Also, not all dongles support Master mode to be an access point. \$\endgroup\$ Mar 21, 2013 at 18:55
    \$\begingroup\$ What is "cheap" here ? What is your budget ? What are your volumes ? The Athros and Broadcomm of the world are not structured to deal with low volume users, so your observations about lack of datasheet is quite spot-on. Also, are you really stuck to STM32 F1/F2 MCU's ? Or are you open to exploring alternatives ? \$\endgroup\$
    – bdutta74
    Apr 20, 2013 at 13:51
I realize its been 4 years after this question has been asked, but here's one worth considering (as of 2017).
ESP8266 or its successor ESP32.
  • Can be interfaced via USART + AT commands or directly programmed using a port for Arduino IDE
  • Available on aliexpress/ebay for about $2 for the minimal board (ESP-01)
  • Available in multiple board configurations
  • Specs can be found here
Why don't you give a try to the one that is advised for Rasberry-pi. I have never tested it for such purposes but should be fine. Here is a link to buy it: Wipi
    \$\begingroup\$ This would require a USB host interface, which I don't believe the mentioned microcontrollers possess. It could also likely require more software support that will fit in their memory. \$\endgroup\$ Mar 21, 2013 at 18:55
I believe TI CC3000 is worth trying. It looks like an all in one module (Embedded IP stack) and said to be able to work with low speed/memory MCUs such as MSP430. It has SPI host interface. Here is the wiki page http://processors.wiki.ti.com/index.php/CC3000 . Also there is a development module https://estore.ti.com/CC3000EM-CC3000-Evaluation-Module-P4257.aspx which you can connect to TI Launchpads.
