I'm using an HCPL-7840 (Isolation Amplifier) on a project.
Its datasheet says its equivalent input impedance is 500 kΩ, but impedance is frequency dependent and I'm going to use it in a DC application. So I guess for my application 500 kΩ is not really relatable.
So I did an experiment where I used a resistor divider, kept R1 fixed and tried out 4 different values for R2 (0, 12k, 24k, 51k), measuring the \$V_{\mathit {div}}\$ in each case and considering that there's this \$R_{\mathit {in}}\$ in parallel with R2:
In this experiment, my empirically calculated \$R_{\mathit {in}}\$ is around 25 kΩ during all 4 experiments.
- Any opinions if this is an OK method to find out the \$R_{\mathit {in}}\$ value @ 0Hz?
- Should I be able to read the input resistance with a multimeter between pins 2 and 3? (Currently, I can't)
