I'm studying AC adapters, and to check about waveforms while changing parameters I did a simulation of this circuit:
Then I wanted to plot also the rectified waveform, so I added a second diode and a big resistance (sorry if this circuit doesn't use the internal CAD, but I was unable to find how to insert two schematics: if I tried to insert a second one, the first was deleted):
so on the 1G resistance there should be the rectified voltage, and the resistance should be big enough to not influence the circuit.
It seems to work, but what I don't understand is that there seem to be a disturbance on the secondary of the transformer, and on the rectified waveform (green on the left graph is the primary of the transformer):
So the secondary voltage has the positive part of the wave distorted, and the negative which is thicker, like there was some very rapid oscillation; and the rectified wave has the same distortion.
I tried experimenting with the simulation, and it seems to be due to the capacitor, since if I delete it the waveforms are a non distorted sines and the rectified waveform with no distortion; I'm not sure if this is something real, or an error of the simulator.
As for the diode, there is a parameter I don't know ("Current At Above Voltage"), but their model as given in the simulator is:
- saturation current: 171 nA
- forward voltage: 806 mV (but the distortion are the same with 0)
- current at above voltage: 1 A
- emission coefficient: 2
Are those distortions something to be expected? If so, why?
As simulator I used Circuit JS.
