What does the encircled "2-" designate in the technical drawing below? Is it some standardized/common designation of something? "R" stands for the radius, and the numbers refers to the values in mm.
The picture is an excerpt from the 6th page of this document. (I've added the red circles)
It means that there are two objects with that dimension. The same shape exists on the right-hand side of the FFC without dimensions, so "2-" is letting you know that side is the same as the left.
It is specifying that there are two of those areas sharing the same dimension: -
