Is there any breakout board like this for 1.27 mm to 2.54 mm pitch?
Example for 1.27 mm:
Example for 2.54 mm:
I also appreciate any hint how to perform this conversion on any other cheap way.
    \$\begingroup\$ Shopping questions are off topic, but you're looking for an SOIC to DIP adapter board. \$\endgroup\$
    – user17592
    Mar 21 '13 at 21:02
  • \$\begingroup\$ Unless I found a really great price, this would be something that I'd order through oshpark.com once I found (or created) the appropriate Eagle/Kicad/whatever files. \$\endgroup\$ Mar 21 '13 at 21:10
    \$\begingroup\$ I got some from Sparkfun, in Germany available through Watterott. \$\endgroup\$
    – starblue
    Mar 21 '13 at 22:44
Many! http://www.futurlec.com/SMD_Adapters.shtml are perhaps the least expensive. Digikey stocks Surfboards. My favorites are from http://www.proto-advantage.com/store/, who will actually order the IC for you and solder it down before shipping.
This kind of breakout board is often called breadboard adapter. Here's an example.
more details on manufacturer's web site: http://www.beldynsys.com/singledual.htm
more manufacturers:
http://www.schmartboard.com/index.asp?page=products_so
http://www.capitaladvanced.com/9000ser.htm
edit
Old thread on a similar subject.
