I have 2 ATTiny85 and a NPN CS-9011 used as a switch. They are both powered by the same 3.3V. I use pin 1 to run the base of the transistor with a 1K resistor. This is not working after an afternoon of tests. I can turn on a sensor, tested with BME280, with this set up but not an ATTiny85. Should I use another Transistor? Or can someone show me that the calculation that my Base resistor is wrong?
ATTiny85 Maximum DC Current per I/O Pin 40 mA
