Hi I'm new to electronics and have little idea how electricity works. I have a motorcycle and wanted to add two LED lights. I want to have one switch in both LED but with different sources.
The first LED (which will be placed in front of the motorcycle) is from the battery, so when I turn on the switch the first LED will turn on. The second LED (which will be placed at the back of the motorcycle) is from the brake light, so whenever I press the brake and the switch is on the second LED will turn on but if I press the brake and the switch is off the second LED will not turn on. Is this possible?
