I'm a bit confused since people said those resistors would draw more power the lower its resistance is, and one way to reduce its resistance is reduce its length.
- Will it draw more power the shorter it is?
- If so, will it stop working past certain point due to temperature being too high?
- If yes, how to find the safe operating range for that heating resistor?
Currently I'm making a heater with "Nikelin" wire as a resistor heater in the form of a coil. I can't find the specification sheet for it anywhere. That "Nikelin" might be called something else in other places. All I know is that it is called that here in Indonesia. I can't even find the manufacturer. Only see it being sold in online and electronic stores.
