I'm using the FPGA board EasyFPGAv2.2 which have Altera Cyclone IV with chip EP4CE6E22C6 and I made a verilog program to generate VGA 640x480 60Hz signal. It works great dividing 50MHz by 2 generating 25MHz clock frequency. But now I want to go up and generate a VGA 800x600 signal and for this is necesary to have a 40MHz clock. I'm using Quartus Lite 20.1 and I dont know how to achieve this step. I'm newbie with FPGA and Quartus software. Thank you.
\$\begingroup\$ 0 I don't know enough of the details to write a good answer, but I can suggest a direction for you to research. I see that the FPGA you are using has 2 PLLs. Using a PLL could be a good way to generate a 40 MHz clock output based on a 50 MHz clock input. \$\endgroup\$– B PeteMay 13, 2022 at 1:08
\$\begingroup\$ You'd typically use a PLL to do this. The EP4Cx6E22 device has 2 multipurpose PLLs which would be suited. You'll also need to ensure that you watch the 'LOCK' bit (essentially a PLL valid/ready bit) to know that the desired frequency arrangement is met. \$\endgroup\$– M1GEOMay 13, 2022 at 1:28
\$\begingroup\$ Thank you very much. I understand what you suggest, But I dont know how to doit in Quartus :( \$\endgroup\$– Yury EucedaMay 13, 2022 at 3:18
1 Answer
Use a PLL. Divide your 50 MHz by 5 to get 10 MHz. Then configure the feedback divider in the PLL to divide by 4, and you'll get 40 MHz.
