Here I have a series LCR circuit with resonant frequency greater than 200Hz. Is there a way to know whether this circuit is an inductive or a capacitive load?
Edit: The only additional information we have is the phase shift between the inductor (with resistance r) and the resistor which is +45 degrees.
Here is the schematic:
Below are plotted voltages of the inductor (plot b) and the resistor (plot a.). The X-axis refers to the time with scale π/4 by division and Y-axis represents the voltage with scale 1V by division.
    \$\begingroup\$ Welcome! Please embed a schematic. \$\endgroup\$
    – winny
    Commented May 13, 2022 at 12:57
  • \$\begingroup\$ Label your axes! What are the two different curves supposed to be? \$\endgroup\$
    – Hilmar
    Commented May 13, 2022 at 13:08
  • \$\begingroup\$ @Hilmar As mentioned the curve b refers to the inductor voltage and curve b refers to the resistor voltage. \$\endgroup\$
    – DINEDINE
    Commented May 13, 2022 at 13:16
Yes. The circuit will have inductive reactance when the driving frequency is above the resonant frequency, and it will have capacitative reactance when the driving frequency is below the resonant frequency.
  • \$\begingroup\$ +1 for answering the actual question asked :) \$\endgroup\$
    – earl
    Commented May 13, 2022 at 13:21
  • \$\begingroup\$ I get it .Thanks for answering. \$\endgroup\$
    – DINEDINE
    Commented May 13, 2022 at 13:24
