14
What's the practical use of ground coupling on modern DSOs? I know that it can be useful on analog oscilloscopes to adjust the ground exactly to a graticule line, but from what I've seen, most of the digital scopes have a sort of marker which shows exactly where the ground is on the screen, which removes the need for ground coupling.
Is there any other use for that option that I'm not aware of?
A switch which DC-couples the scope input to ground could reveal whether there is an offset in the ADC which shows up as a displacement from the marker where ground should be.
The switch also disconnects the probe's signal (it will not simply short out the probe!), so you can use it as an off switch break the probe from the circuit without disconnecting it. It's possible that the probe's ground clip is also cut when the input is in that state, which is even better since it is complete isolation.
If you're probing some node which is supposed to be at ground, the switch can give you a quick A/B comparison to see how close that node is to ground. If the flatline jumps slightly, it's a bit more visually obvious than comparing against the marker.
protected by Kortuk Mar 23 '13 at 0:39
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
