I was doing a project of a electronic load and I bought a hall effect sensor to measure the current through the mosfets in this project.
Due to some instability in the hall effect sensor, I needed to measure the current in another way.
And came in my head, why not to use the voltage below the mosfet or between the 0.5 Ohm resistors to measure the drain current of the mosfet (Id).
The mosfets are all IRF3205.
The image below will illustrate what I want to do:
Theres some way to get the formula to calc the drain current (Id) of these mosfets (using this voltage measure point) ?
Further, this electronic load will take sources with max 12 Volts and will drain of these loads a maximum around of 15A.
