I'm attempting to create a guitar pedal using diodes to clip the audio signal and create distortion. Specifically, I'm trying to create a circuit with variable clipping by using a circuit that acts like a diode which has a variable voltage drop from around 0.7-3.5. It's also possible to use a Zener diode type circuit with a variable breakdown voltage.
I believe that the TL431 IC would serve this purpose, but the forward voltage drop is specified from 2.5-5 V, which is too high for the application. Are there any other components or circuits that perform a similar task with a lower voltage level?
Thanks in advance for any help
