If I have 5 AA batteries powering a locking device, what would be the maximum combined available amps available?
I know that 1 AA battery has 50mA but I do not know if I can just combine that value to get 250 mA.
It depends on how you connect the batteries. If they are connected in series, you get the sum of all the voltages and the current (amps) of a single cell. If you hook them up in parallel, exactly the opposite happens: you get the voltage that a signle cell would output and the sum of the amps that all the cells output together.
So you have two options:
Connect the batteries in parallel and get 1.5V (I assume that's the voltage of one of your AA batteries) and 5 * 50mA = 250mA
Connect them in series and get 5 * 1.5V = 7.5V and 50mA
I don't know what the operating voltage of your device is to tell you which arrangement is needed in your case but these are your only options if you keep these batteries.
P.S.: 50mA of maximum current sounds like very little for a AA battery. I've powered a lot of power-hungry things using them
