I'm looking to power a 50W load approximately 140m away using 48V DC. At the far end I will use a DC-DC converter to convert this to 12VDC where it will power a small DC powered network switch I have.
I was thinking that I could use a single copper pair (+ & -) cable to do this however there might be quite a bit of power loss due to the high current running to the end load. I was working out the maths and I believe that if I were to run two copper pair cables in parallel I would both decrease the voltage drop before my load and reduce the power loss. Basically, I would have two positive cables running from my power source to my load - connected to a voltage source in parallel. I would then recombine these two cables at the far end. The same applies to the negative return path cables.
I think this because I would be halving the total current flowing through each of the cables going to and from my load. Since power dissipated is current squared times resistance I figure that I will be able to halve my power losses. Similarly, my voltage drop will also be halved as the current through each cable is halved.
I worked out that 140m of 14AWG has a resistance of around 1.16ohm. I know my load will run on 12VDC but still consumes say 50W of power so its equivalent resistance would be around 46ohm given the 1A current flowing (48V x 1A gives roughly 50W).
Just wondering if this is correct or I if have a misunderstanding somewhere.
