-1
I'm new in PLC programming and used only Siemens Logo. The problem I'm facing is that I can not find any gateway device that can directly send the data to server. I want to avoid using PC for simply sending or receiving data. I checked Ignition software. It's great, but it needs a PC. I found many gateways in Alibaba, but those are not programmable like PLCs.
    \$\begingroup\$ hasn't the logo already an ethernet device? IIRC it's designed to use some kind of cloud service. Just attach it behind a router and it should be already able to communicate \$\endgroup\$ May 24, 2022 at 5:57
  • \$\begingroup\$ mall.industry.siemens.com/mall/en/WW/Catalog/Product/… \$\endgroup\$
    – Sadat Rafi
    May 24, 2022 at 6:08
  • \$\begingroup\$ I think you are talking about this. I just found it. \$\endgroup\$
    – Sadat Rafi
    May 24, 2022 at 6:09
Safety for a PLC is very important, you don't want malware in your PLC or that third parties have access.
Use a VPN gateway, such as Tosibox, EWON or develop one yourself with Mikrotik.
They provide you with safe remote access to the PLC, and optionally, the PLC can access some internet. They also fix any CGNAT issue.
In any case, you PLC must never be found by shodan.io or similar network mapping indexers.
