Why do some dc-dc buck or boost converters do not have the switching frequency value in their datasheet?
For example: Link does not have switching frequency ?
Is it possible to get power dissipation of a dc-dc boost converter?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhy do some dc-dc buck or boost converters do not have the switching frequency value in their datasheet?
Try this: -
The device you linked is a constant ripple hysteretic converter and therefore the lower the load current, the lower the switching frequency: -
As you can see, the ripple voltage is constant pretty much across all load currents and, this supports the fact that switching frequency is proportional to load current: -
Most converter data sheets allow this to be found. From the above data sheet this graph can be used to find power dissipation: -
So, with an output (load) current of (say) 20 mA and an output voltage of 24 volts, the efficiency from the graph is 80%. The output power is 20 mA x 24 volts = 0.48 watts therefore, the input power is 0.48/0.8 = 0.6 watts.
This means that the losses in the circuit are 0.6 watts minus 0.48 watts = 0.12 watts.
