I need to buy some coax cable for TV via satellite. I see they are marked in dB: 135, 130, 120 down to 95. Then there are multiple layers (up to 5) and shielding copper (cu) vs aluminum (alu.)
Is my understanding correct that the higher the dB number the better the cable? Is cu shield better than alu?
I assume for the core cable as well, copper is better than alu.
I need to put it in the wall, and just want the best (i.e. most future proof cable), with minimum potential interference (5G, LTE, etc.)
