I am using the SCT2331 (a clone of the Diodes AP63200, with 400KHz switching frequency instead of 500KHz). The design works with an inductor from Coilcraft (LPS3314-103), but when I try a different, same value inductor, Bourns SRR4828A-100M, the regulator doesn't generate the correct voltage, and is stuck in LDO mode. The layout supports the Bourns footprint (larger). Both inductors have ferrite core, the Bourns has lower DCR, (100mOhm vs 330mOhm) and lower SRF (30MHz vs 55MHz). What can I do to get the design to work with the Bourns part?
