I have incomplete details of a very interesting RCCR oscillator circuit that, back in 1960, used just 3 transistors as the amplifier. In those days, the transistors were germanium PNP, almost certainly. I cannot see how just 3 transistors can do that, because the circuit requires to be driven in push-pull with some gain on the in-phase (push) side. I need suggestions how to do that, using Si transistors, of course. The frequency range I need is 20 kHz to 60 kHz. In this range, ordinary op-amps can introduce unwanted phase-shifts unless the closed-loop gain is kept very low.
I am including the original article and the results of a Spice simulation. Original article
