I have this circuit:
I want to find the input impedance \$R_in\$ with a PSPICE simulation. I'm not sure how to go about this.
    \$\begingroup\$ If Vin and Iin are in phase, then Rin = Vin / Iin. Otherwise Rin = Vin / Iin * cos(theta) where theta is the phase difference between Vin and Iin. Cos (theta) is also known as the power factor. The complex impedance has a magnitude of Vin / Iin and its angle is theta. \$\endgroup\$
    – user57037
    May 30, 2022 at 18:08
    \$\begingroup\$ Do an AC Analysis and just calculate Zin= v(Vin) / i(C1) if you use a capacitor at input. So, you get the input complex impedance versus frequency. \$\endgroup\$
    – Antonio51
    May 30, 2022 at 19:05
Do an AC Analysis;
Just calculate \$Zin= v(Vin) / i(C1)\$
Made with microcap v12, spectrum-soft.
