I am trying to use a 1x4 keypad with an ESP32. I am using this keypad and this ESP32 (30 pins); I am also using this keypad library.
I have only pins 14, 15, 34, 36 (VN), and 39 (VP) free on the ESP32, the others are in use.
When I think of it on paper, I should be able to use the input-only pins for the keypad.
My code looks like this and is not working. Only the "2" button is working properly.
#include <Keypad.h>
const byte ROWS = 1; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1', '2', '3', '4'}
byte rowPins[ROWS] = {14}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {39, 15, 34, 36}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup() {
  Serial.begin(9600);
void loop() {
  char key = keypad.getKey();
  if (key) {
    Serial.println(key);
Why this code is not working I do not understand, but I know pins 34, 36 and 39 are input-only pins and those pins don't have an INPUT_PULLUP function. But in the library there is this code in keypad.h:
#ifndef INPUT_PULLUP
#warning "Using  pinMode() INPUT_PULLUP AVR emulation"
#define INPUT_PULLUP 0x2
#define pinMode(_pin, _mode) _mypinMode(_pin, _mode)
#define _mypinMode(_pin, _mode)
do {
  if (_mode == INPUT_PULLUP)
    pinMode(_pin, INPUT);
    digitalWrite(_pin, 1);
    if (_mode != INPUT_PULLUP)
      pinMode(_pin, _mode);
} while(0)
#endif
In my opinion this code is the problem. I've tried all the possibilities I could think of, but it still doesn't work.
  • \$\begingroup\$ Do not use the keypad library because this is not a key matrix, just 4 switches. It is absurd to use 5 pins to read 4 switches. Connect the common contact to GND and the switches to 4 inputs. Enable the internal pull up resistors of these inputs (if available) or use external resistors and just read the inputs. \$\endgroup\$
    – Jens
    Jun 2, 2022 at 2:35
  • \$\begingroup\$ well if I use normal GIOP pins with this library, everything working normal \$\endgroup\$
    – mehmet
    Jun 2, 2022 at 5:35
Pins 35, 37, 38, and 36 are input-only and do not have an internal pull-up resistor. It is required to use an external pull-up resistor in order to detect changes. Many guys talk about a 10 resistor, I just tested with a 2 kΩ one.
Hope this helps somebody.
