When considering negative feedback systems such as sine wave oscillators, amplifiers and control systems with regard to stability (loop gain and phase) it is best to consider sinewave oscillators separately to amplifiers.
Firstly, consider a sinewave oscillator
As can be seen from the block diagram, a sine wave oscillator is a closed loop. There isn't really an input or an output but the signal can be tapped off from the right hand side as shown.
It is possible to understand intuitively how a phase shift around the loop of 0 degrees, 360 degrees or 720 degrees etc when the gain around the loop is 1 (unity) leads to the returned signal around the loop arriving back where it started in phase and of the same magnitude. Hence a stable steady amplitude oscillation is achieved.
In the case of the wien oscillator the feedback gain is 1/3 which means that the forward gain must be set to 3 in order to achieve unity loop gain. 1/3 * 3 = 1
In a practical oscillator, some form of automatic gain control would be utilised in order to set the loop gain to greater than one at power-up to enable the amplitude of the sine wave to build up. Once the required amplitude is reached the loop gain is automatically reduced to 1 to stabilise the amplitude of the sine wave.
Intuitively it is possible to see how a loop gain greater than one with loop phase of zero degrees causes the signal around the loop to arrive back where it started and add to the amplitude, increasing its level.
Now consider an amplifier which can be considered in a similar manner to a generalised control system.
The amplifier's block diagram is similar to that of the previously considered sine wave oscillator. However the amplifier's block diagram has an input and a summing junction added.
Now for the amplifier, instability occurs when the loop gain is 1 (unity) and the loop phase is 360 degrees, but for the amplifier the whole loop includes the summing junction. The summing junction on its own has a constant -180 degrees inversion. This means that the Forward gain and Feedback gain would require a combined phase lag of -180 degrees in order to achieve the full 360 degrees lag necessary for instability.
When you see references to "-180 degrees loop phase lag at unity gain causes instability" it is referring to a negative feedback system with a summing junction and the -180 degrees lag of the summing junction is being omitted (not included) in the quoted loop phase lag value.
It is interesting to note that for a sine wave oscillator, a loop gain of 1 with loop phase lag of 0 degrees, 360 degrees, 720 degrees etc leads to constant amplitude oscillations. Increase the gain above unity and the amplitude will slowly and constantly increase. Reduce the gain below unity and the oscillation will die away.
This is in contrast to the amplifier type system (with an input and summing junction) where unity loop gain (or greater than unity) with a loop phase lag of 360 degrees will theoretically cause infinite amplitude oscillations. Obviously in practice the theoretical infinite amplitude will be limited by the amplifier's power rails.
For a sine wave oscillator, at the frequency of oscillation, the loop gain will be unity and the loop phase will be 0 degrees, 360 degrees, or 720 degrees etc. This point is referred to as marginal stability and it is right on the border line between negative feedback and positive feedback occuring. Although for a sine wave oscillator steady amplitude oscillations occur at this point.
For an amplifier type system, a loop gain of 1 (unity) with a whole loop phase lag of -360 degrees is also referred to as marginal stability which is also right on the border between negative feedback and positive feedback occuring but, as already mentioned, in an amplifier type system, the point of marginal stability leads to theoretical infinite amplitude.
In a sinewave oscillator, the point of marginal stability must be obtained in order to a obtain a steady amplitude sinewave. This marginal stability point is achieved with the aid of automatic gain control.
In an amplifier type system the point of marginal stability would be almost impossible to obtain and, in reality, a real system would have a loop gain of either less than one at -360 degrees lag (stable) or greater than one at -360 degrees lag (unstable).
