I'm working on RF Receiver, it is required to use I/Q Mixer for IF downconversion. Specification as follows below
LO/RF Frequency: 0.5-1 GHz
IF Frequency Range: DC-1000 MHZ
What will happen if I drive RF and LO at the same frequency, for example, RF: 500 MHz, IF: 500 MHz
Can I expect the DC output for I/Q? Or let me know what output can I expect?
  • \$\begingroup\$ You'll find output at both 0 Hz and 2*F = 1 GHz. For the DC case, search "homodyne" or "direct conversion" receivers. They have their own unique problems... \$\endgroup\$
    – user16324
    Jun 5, 2022 at 14:32
  • \$\begingroup\$ Thanks a lot. Is there power level will split in I and Q outputs? As datasheet it was mentioned 7.5 dB conversion loss which means total loss will be 7.5 dB when combined it I&Q signals together. can you please clarify me ? \$\endgroup\$
    – Dinesh
    Jun 6, 2022 at 13:08
  • \$\begingroup\$ No I can't, sorry. \$\endgroup\$
    – user16324
    Jun 6, 2022 at 13:39
