We have to find the equivalent resistance between A and B.
My attempt:
Let's simplify the circuit.
Now,
$$\frac{1}{R_P}=\frac{1}{5+5}+\frac{1}{5+5}+\frac{1}{5}$$
$$R_P=\frac{5}{2}\Omega$$
However, this is not the correct answer; the correct answer is 3.125 ohm. Why is that?
Edit:
I was able to simplify the circuit correctly:
  • 6
    \$\begingroup\$ You simplified the circuit incorrectly : try again. \$\endgroup\$
    – user16324
    Jun 5, 2022 at 14:35
    \$\begingroup\$ You've redrawn it differently. Try numbering the nodes if you're having trouble. \$\endgroup\$ Jun 5, 2022 at 14:35
    \$\begingroup\$ Is R2 really connected to B as you've drawn it? \$\endgroup\$
    – brhans
    Jun 5, 2022 at 14:37
This problem is a good example of why diagonal schematic symbols/connections can make it more difficult to interpret schematics correctly. Re-drawing the circuit without the diagonals should make things more clear:
Original circuit (re-drawn)
Steps given here for solving: steps for solving circuit
