I made the RFM96 LoRa Radio Module by adafruit communicate to each other. The next step I want to do is connect to it to a gateway, which is either the RAK7371 Developer Base or RAK2287 Concentrator Module. After connecting these gateways to The Things Network (TTN), I noticed that it doesn't get or reflect the data from the RFM96 module in the gateway. I didn't see the data I sent using the module.
After doing researches, I may have found out what might be the reason -- RFM96 LoRa Radio Module is not considered as LoRaWAN end-node as needed by the gateways.
I would like to confirm to you and hoping that someone can shed light on this matter.
Thank you!
  • \$\begingroup\$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. \$\endgroup\$
    – Community Bot
    Jun 7, 2022 at 5:24
LoRa and LoRaWAN are not the same.
What are LoRa and LoRaWAN? tells you the details: -
  • \$\begingroup\$ Thank you for the clarification! Actually I already registered my RFM96 radio module to the TTN. However, I didn't see the data it sends. This what I got every time I open the serial monitor of my Arduino IDE. Starting Packet queued 1843: EV_JOINING 2122: EV_TXSTART FAILURE May I humbly ask for any insights I could take to address this? Thank you so much. \$\endgroup\$ Jun 8, 2022 at 2:06
  • \$\begingroup\$ Honestly I have no idea. \$\endgroup\$
    Jun 8, 2022 at 8:47
