Here is a code from VUnit Avalon Master BFM:
entity avalon_master is
  generic (
    bus_handle          : bus_master_t;
    use_readdatavalid   : boolean := true;
    fixed_read_latency  : natural := 1;  -- (bus cycles).  This parameter is ignored when use_readdatavalid is true
    write_high_probability : real range 0.0 to 1.0 := 1.0;
    read_high_probability : real range 0.0 to 1.0 := 1.0
  port (
    clk           : in  std_logic;
    address       : out std_logic_vector;
    byteenable    : out std_logic_vector;
    burstcount    : out std_logic_vector;
    waitrequest   : in  std_logic;
    write         : out std_logic;
    writedata     : out std_logic_vector;
    read          : out std_logic;
    readdata      : in  std_logic_vector;
    readdatavalid : in  std_logic
end entity;
There are so many ports that just say std_logic_vector without giving any bounds. This is obviously only for use in simulation actually. How is this even valid VHDL?
  • \$\begingroup\$ Which version of VHDL? 2008 and newer add capabilities that earlier versions didn't have. \$\endgroup\$
    – user16324
    Commented Jun 7, 2022 at 12:39
  • \$\begingroup\$ I am not sure but this could be VHDL 2008. It is code from the VUnit testing framework. \$\endgroup\$
    – gyuunyuu
    Commented Jun 7, 2022 at 13:15
    \$\begingroup\$ Yes for all revisions of VHDL. It is similar to subprograms in this way. However, your synthesis tools may or may not like this. So I primarily use it for verification. Good news with Vivado below, however, I would still be cautious with synthesis code. \$\endgroup\$
    – Jim Lewis
    Commented Jun 7, 2022 at 13:57
  • \$\begingroup\$ Thanks Jim, this is code for a BFM. \$\endgroup\$
    – gyuunyuu
    Commented Jun 7, 2022 at 18:41
This unconstrained declaration is valid, but it depends on another definition outside this module. Note that no "generic" declaration is required for this simple D Flip-Flop example:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity uncon_dff is
    Port ( d : in STD_LOGIC_VECTOR;
           clk, rst : in STD_LOGIC;
           q : out STD_LOGIC_VECTOR);
end uncon_dff;
architecture Behavioral of uncon_dff is
begin
    process (clk, rst)
    begin
        if (rst = '1') then
            q <= (others => '0');
        elsif rising_edge(clk) then
            q <= d;
        end if;
    end process;
end Behavioral;
The top level design defines the ranges of the vectors at the instantiation (from the local signals/inputs/outputs):
library IEEE;
entity top_dff is
    Port ( d : in STD_LOGIC_VECTOR (7 downto 0);
           q : out STD_LOGIC_VECTOR (7 downto 0));
end top_dff;
architecture Behavioral of top_dff is
    component uncon_dff is -- no range here (unconstrained)
    end component;
begin
    dff : uncon_dff port map ( -- ranges inherited
        d => d, clk => clk, rst => rst, q => q
end Behavioral;
Which generates the expected logic:
This was tested on Vivado using VHDL 2008. If the top level design mistakenly defines different ranges for 'd' and 'q', the synthesis fails:
[Synth 8-690] width mismatch in assignment; target has 9 bits, source has 8 bits ["/dev/shm/project_1/project_1.srcs/sources_1/new/uncon_dff.vhd":18]
