Solar panels have a non-linear voltage/current curve. The actual voltage and current depends on the load. This graph is from a different solar panel (from this answer) with more current - same voltage though:
The specifications for your solar panel:
Wattage (Wp): 10
Voltage at Max Power, Vmp (V): 16.85
Current at Max Power, Imp (A): 0.59
Open Circuit Voltage, Voc (V): 20.9
Short Circuit Current, Isc (A): 0.65
number of cells: 36
You show two motors. The first one absolutely won't work because it's designed for 220V AC. The second one is designed for 9V and 0.22A. If you connected it to this panel it would probably get something like 18V and 0.44A, and burn out.
You have a few options:
- Get a pump that's a good match for the panel, then connect it directly. If you find a 3W pump designed for maybe 17-18V then it will probably work (I won't guarantee it). The current will be lower than Imp, so the voltage will be higher than Vmp, so you can get a pump designed for whatever voltage the panel actually puts out.
The voltage should be an approximate match. The current doesn't need to match. But the voltage should approximately match what the solar panel voltage will be at that current, which you'd have to guesstimate.
It doesn't have to be an exact match - only approximate. The pump will be okay with a bit too much power or a bit too little power, just not way too much or way too little.
- Use a DC/DC converter to convert the solar panel output to a stable voltage (whatever voltage you need for the pump). This is the best option. The converter will even try to keep the voltage steady when the sun goes behind a cloud.
Note: If the solar panel can't put out enough power (e.g. at night), there is a chance the converter will get stuck drawing the short circuit current and you'd have to unplug it and plug it back in to make it work normally. I'm not sure this can be calculated without knowing all the technical details of the converter design. Since other people are using them, I guess this problem doesn't happen.
- Add a big resistor to waste current and force the solar panel voltage down to the voltage the pump needs. It's not as good as a DC/DC converter, but it could be cheaper if money is a problem.
