I want to design my own power supply. I know it can be dangerous for someone whit not much of experience, but at least I want to learn it on the paper!
I am aiming for a 12 V/10 A (120 watts) DC switching power supply.
What I think the system block should look like
1- 220 V AC to some DC value this will be mainly a transformer, plus usual filter caps, etc...
2- A switching IC to convent the secondary side of the transformer to 12 V
3- Some safety ideas:
- over current -> monitor output current with a shunt resistor
- over voltage -> ???
- over temperature -> a microcontroller with some SMD temperature sensors around hot areas (switching FET, etc)
The questions are:
I would need to search for a transformer which is rated for 12 A? 12 A being my output, so maybe the transformer must be rated higher because some energy will get lost?
Are there any standard schematic (opensource hardware, etc) that I can take as reference?
Where I can find any reference?
In general what should be careful about, dos and don'ts?
