I have an application that requires a transformer with 120VAC 60Hz on the primary and 7VAC/11VAC (200mA) on the secondary. Unfortunately, while this part is available in some countries I have not been able to get one shipped to the US (so far).
This ebay listing shows a transformer which converts 115VAC to 14VAC and 7VAC (250mA), which is very close (and the current rating is appropriate), so in theory I just need an additional step-down to get from 14 to 11VAC. I don't know the input tolerance of the board that uses the 11VAC otherwise I would try this directly since I assume it's just regulated to some DC value.
Unfortunately, the step-down turn ratio (~1.27:1) is not so easy to find, and the closest I've located so far is this digi-key component, but it's intended for DC-DC SMPS.
I'm guessing that this would not have the right properties to work for my AC application, so I was hoping someone would please comment to confirm, and if there is a good alternative for what I'm trying to do.
Edit: Sorry I wasn't clear before, but this is a one-off repair, so I was looking for a close replacement for the part I couldn't source. Both the 11VAC and 7VAC outputs are needed on the secondary, or an equivalent.
