I found these schematics for an audio mixer.
I reproduce the mainpart of the schematics. A first stage of input buffers before each in line consisting of an opamp is not reproduced. I am only interested in unipolar mode.
I recognize a summing inverting op amp circuit. After the first op amp we have
$$ V = - \sum_i V_i \frac{1}{1 + R_i / 100k} $$
Where \$R_i\$ is the resistance value of the i-th potentiometer.
If the potentiometer is on the far right, we then have a coefficient of \$1\$ in front of \$V_i\$. It is ok.
When you turn the potentiometer on the far left, for a potentiometer of 25k, you then have a coefficient of \$ \frac{1}{1 + 25k / 100k} = 0.8\$.
The documentation says:
When in unipolar mode, all pots feeding that output behave in regular fashion, that is when the knob is fully counter-clockwise, no signal from the associated input passes into the mix. As the knob is advanced clockwise, a greater portion of the signal passes into the mix.
I don't understand how 80% of the signal can be considered no signal.
It seems that I am missing something.
