Suppose we have this circuit
How to do nodal analysis for this circuit?
Is it $$5-\frac{5-V_{A}}{2}-V_{A} = 0$$?
or $$5-\frac{5-V_{A}}{2} - 2 \frac{5-V_{A}}{2} = 0$$
EDIT
By
  • \$\begingroup\$ Notice that 5 has a unit of voltage and (5 - Va)/2 will have a unit of current. So you cannot subtract current from a voltage (subtract apples from bananas). \$\endgroup\$
    – G36
    Jun 14, 2022 at 18:04
  • \$\begingroup\$ Yes you are correct. \$\endgroup\$
    – Miss Mulan
    Jun 14, 2022 at 18:06
You need to introduce \$I_M\$ into the fray or you'll just get 0 = 0 and that helps nobody: -
$$5 = 2\cdot I_M + V_A$$
Where \$V_A = 2\cdot I_M\$ (as per the dependent source) so: -
$$5 = 2\cdot I_M + 2\cdot I_M$$
And, \$I_M=1.25\text{ amps}\$ and \$V_A = 2.5\text{ volts}\$. Sanity check: -
