I have a voltage divider as shown in the diagram below - 68k, 33k in series; output voltage Vs is measured across the 33k resistor. The arrangement is used to measure voltage from a 5V nominal source on a PCB. When the input is 5.1V, I measure Vs = 0.6V and the voltage across the 68k to be 4.5V using a digital multimeter, when I was expecting Vs to be 1.6V.
I have repeated the measurement after desoldering the Zener and the capacitors, but the result is the same. The capacitors are ceramic 0805, resistors are 1/8W 0805. I am wondering if there is some fundamental error or I am missing something obvious? Any pointers much appreciated!
