I'm working on a boost converter board to power an OLED display, specifically a Midas Display MCOT128064SV-WM, off of 5V USB bus power (the VBUS pin on a Raspberry Pi Pico powered via USB).
I referenced this TI WEBENCH design:
I had this design printed and assembled, but it outputs around 12.2V (originally stated as 12.5V) when I applied power, instead of the 13V I'm expecting. Is there anything wrong with this circuit? I'm new to electronics design, so I'm pretty sure I'm missing something.
Edit to add: \$V_{out}\$ reaches 12.18V, and \$V_{FB}\$ only reaches 0.824V, instead of 0.795V.
Edit: After posting this, I found out R2 was ordered as a 1Ω resistor, not 100kΩ. Effectively, the upper half of the resistance divider around FB was 10% too low, so the output voltage was also about 10% too low.
