I have a 0.08A 12V fan that I'd like to run on a 24V PSU. I have a 1/4W resistor kit with several different resistor values and a max input 23V buck converter. Can I add a resistor in series before the buck converter to bring the voltage of the PSU safely down to 22V? I've calculated that I need a 25ohm resistor, is that correct? I've included an image of my proposed setup.
This is a datasheet for the buck converter I have https://matts-electronics.com/wp-content/uploads/2018/06/MINI-360.pdf.
