I am using USBLC6 IC to USB pins for ESD protection. In the diagram in the datasheet, I see that pins 1-6 and 3-4 are shorting. I also want to shorting these pins on the PCB so that the circuit works without using this USBLC6.
Functional diagram (top view)
However, in the example pcb layout image on page 11 of the datasheet, these pins are not shorting.
USBLC6-2 PCB layout considerations
Will shorting these pins on the pcb have any effect on ESD protection?
Yes, that strategy will negatively affect ESD protection.
The equivalent pspice model shows this:
USBLC6 PSpice model
There is an impedance on both sides of the data lines (likely caused by the package leads and bonding wires) which will serve to help the Dlow / Dhigh diodes to shunt unwanted current.
As to how much it will affect your protection, that is another question entirely. What is your purpose for installing the component? Your USB communication will work without it under most conditions for hobbyist or prototype use. Is this a consumer product? Is there a situation where you would not want to install it when you are manufacturing in quantity?
For those prototyping, I have typically used a solder bridge to connect the data lines, in situations where I have not needed or wanted this protection device. The footprint remains on the board and gets populated during manufacturing.
  • \$\begingroup\$ To be used in industrial environment. Actually, I have no serious reason not to install it. During the design, the first thing that came to my mind was shorting, then when I saw a different layout in the datasheet, I got curious. Your answer cleared the question mark in my mind. I will not make a shorting and if necessary, I will make a solder bridge as you say. \$\endgroup\$
    – Mustafa
    Jun 20 at 18:45
